19 years ago
help about flash programmer
Does anyone know what a EPCS identifier is ? When I was erasing my EPCS device I got the following message:
# !/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd E:/cycloneII_sopc_OK/memory_test/Debug
# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="E:/cycloneII_sopc_OK/cyclone.sof
" --output="cyclone.flash"
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS64 --option=cyclon
e.opt E:/cycloneII_sopc_OK/cyclone.sof cyclone.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Allocated 53 megabytes of memory during processing
Info: Processing ended: Thu Sep 06 13:26:04 2007
Info: Elapsed time: 00:00:06
Info: Command: quartus_cpf --no_banner --convert cyclone.pof cyclone.rpd
Info: Allocated 51 megabytes of memory during processing
Info: Processing ended: Thu Sep 06 13:26:10 2007
# Programming flash with the FPGA configuration
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x01004800 --sidp=0x0
1005158 --id=508897094 --timestamp=1189054008 --instance=0 "cyclone.flash"
Using cable "ByteBlasterMV [LPT1]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x01005158: verified
No EPCS layout data - looking for section [EPCS-FF]
Unable to use EPCS device
Leaving target processor paused
# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --epcs --after="cyclone.flash" --input="memory_t
est.elf" --output="epcs_controller.flash"
# Programming flash with the project
1005158 --id=508897094 --timestamp=1189054008 --instance=0 "epcs_controller.flas
h"
Can anyone help me with this problem ?
1 Reply
    File a MySupport question on the Altera WEB site.
    Include all the info you have here.
