19 years agohelp about cycloneII!!!!
hi all I'm using the cycloneII(EP2C20Q240C8).I want to know how to use the pin of PLL_OUTn IN the pin sheet,pin description of PLL_OUTn is:Optional negative terminal for external clock outpu...
19 years agothank you for your help!
I use PLL1_OUTp as single ended clock output(sdram_clk) and PLL1_OUTn as sdd3 of sdram in my design.It doesn't work.If I use PLL3_OUTp as sdram_clk and unuse PLL1_OUTp ,sucessful!!!! But why?
