14 years ago
HDMI/DVI Tx in Cyclone III family device
Hi all,
The idea is to embed a HDMI transmitter inside the Cyclone 3 FPGA. I need to investigate electrical/logical interfaces as well as any needed IP core or driver support. Xilinx offers embedded electrically-compliant TMDS I/O pins in their Spartan 6 family allowing implementation of DVI and HDMI interfaces inside the FPGA. The possibility to perform the same thing in Altera Cyclone is not very clear. At least in the documents I have read (among which: White paper // Using Cyclone III FPGAs for Clearer LCD HDTV Implementation). One of challenges is that HDMI needs up to 10.6 Gbps bitrate @ 350 MHz while Cyclone III can achieve up to 875 Mbps (in their high-speed I/O banks).
There still some other possibilities say connecting a daughter card to the HSMC connector to work as either DVI or HDMI transmitter.
My FPGA board will perform some video processing function on variable resolution video streams (up to 720p @ 60 Hz), then send the streams over TMDS to a high definition monitor with HDMI connector.
My questions are:
- Is it theoretically possible to send such streams without any compression if I am using TMDS protocol?
- Can I just use a DVI Tx in my board, then somehow do a DVI2HDMI conversion?
- Is it possible to use Cyclone´III high-speed I/O banks (primarily designed for differential interfaces like LVDS) for HDMI Tx interface? Are there any electrical constraints? (As you have already noticed I don't need to achieve the HDMI max bitrate, I can survive with much less than that)
- Do I need to have an IP core for TMDS encoding? If so, does Altera provide it?
- Is there any other aspect I have to consider?
This is an industrial project. An expert recommendation will be very appreciated.
    One thing to be aware of, is you will be using a PLL for the LVDS signals, in the HDMI path, and the smaller devices have limited number of PLL's. so you may want to be careful with your PLL utilization.
    Pete
    First sorry I missed this post.. I've been juggling a couple of projects, and didn't see your reply.
    --- Quote Start ---
    The Dedicated differential output buffers on side I/O banks support LVDS transmit at up to 840 Mbps. Is that is why you suggest that sending 720p frame is doable in Cyclone III?
    --- Quote End ---
    Yes.
    --- Quote Start ---
    Apart from that, I'm still a bit confused about I/O pin speed. The fpga specification give the throughput per pin, and not per channel/lane, right?
    --- Quote End ---
    Kind of: they are giving you the number per pin pair, which I'm saying is per channel/lane. The HDMI standard uses three data lanes. So they are specifying the data throughput of the system, which uses 3 lanes.
    --- Quote Start ---
    Another thing, the throughput that the specification gives depends upon the max frequency the fpga could support, right?
    --- Quote End ---
    Yes.
    --- Quote Start ---
    That's said, is it possible to calculate the min I/O pins speed I would need for example to use TMDS protocol for a given resolution?
    --- Quote End ---
    Yes. But you have to take into count vertical and horizontal blanking times as well as the number of pixels. For each resolution however there is a "Standard" clock rate for the resolution that you can simply mutiply by 10 to get the IO rate.
    --- Quote Start ---
    Sorry for all of this confusion, but I'm rather beginner then an expert. I can't sleep at night trying to find answers for these questions.
    --- Quote End ---
    Well, get some sleep.. Life is too short to get over worried about this.
    The "fastest way" to get something working would be to use an "off the shelf" solution attached to the FPGA. That way the HDMI protocol issues should be handled for you.
    http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=66&no=582
    with a compatible dev board.
    For a board solution it adds BOM costs, but you'll save engineering costs. It also be used as an "intermediate" solution so you can have working video base-line while you work out the issues with your own solution.
    --- Quote Start ---
    Thanks Pete for your detailed answer. I will contact u if i hear anything from my manager. There is also this encryption part in HDMI. Is it smthg i have to consider? We won't need any kind of encryption for this application.
    //Update:
    We need help with a MJPEG or H264 encoder that can handle 1080p @ 60Hz. If you think you can help us with that we can discuss further price and target technology. Footprint should be minimum for Cyclone III, EP3C10.
    --- Quote End ---
    No Problem: Someone else responded with an IP solution for this. That's probably the cheapest quickest way to get your H264 encoder vs me building you one, but if you still need some help implementing, let me know.
    If you want to talk to me directly, our company number is 509-922-5629 x327 INFINETIX Corp.
    Pete
    --- Quote Start ---
    --- Quote End ---
    I just saw your MJPEG encoder request by mistake:
    We claim that we have the smallest MJPEG encoder IP-core on the market (about 2600LEs, 5 M9Ks, 8 18b-multipliers, you can also save some multipliers but will get higher LE-usage). It was designed for 1080p30 but can achieve 1080p60 in the fastest speedgrade of Cyclone III.
    We are also considering to make a 1080p60 version for lower speed-grades with a little higher resource-usage if there is a demand.
    www.entner-electronics.com/tl/index.php/jpeg-codec.html
    Thomas
    P.S.: Check out also our EEBlaster (EUR 49,- + shipping + VAT):
    www.entner-electronics.com/tl/index.php/eeblaster.html
    --- Quote Start ---
    The HDMI 1.3 spec has a maximum clock rate of 340 MHz with 3 data channels and 10 bits per channel, that gives you 10.2 Gbps. But that is at the highest resolution. If your maximum resolution is 720p, your clock will be 74.25 MHz for a total of 2.23 Gbps transfer, or 742.5 Mbps per lane. This is doable in the Cyclone 3.
    --- Quote End ---
    --- Quote Start ---
    Yes you need a TDMS encoder, I'm not aware of any Altera core for this, but they do have some image processing cores, so I wouldn't be surprised if they have one. However the specification is available: http://www.ddwg.org/lib/dvi_10.pdf so it wouldn't be too hard to create it if you need it.
    --- Quote End ---
    --- Quote Start ---
    I'm a FPGA/ASIC consultant with video and RF DSP experience, so if you need assistance implementing the design, we can help you out. We also have board design and software engineers on staff. If you are interested feel free to message me through this forum.
    Pete
    --- Quote End ---
    //Update:
    --- Quote Start ---
    The HDMI physical layer is covered by Cyclone 3 LVDS transmitters as far as I see.
    --- Quote End ---
    Do you have any reference for this? Reference design or a link? This would things much easier..
    The question is: Can TMDS be physically interfaced by LVDS?
    I was in fact referring to a standard speed (category 1) HDMI link with 74.25 MHz maximum clock frequency, which is doable without Gbit transceivers.
    --- Quote Start ---
    --- Quote End ---
    --- Quote Start ---
    --- Quote End ---
    Yes
    --- Quote Start ---
    --- Quote End ---
    Yes. There are DVI to HDMI cables readily available online DVI just doesn't have the sound and advanced features of HDMI..
    --- Quote Start ---
    --- Quote End ---
    You should be able to make it work at 720p. I haven't looked into the other electrical constraints to say for sure however.
    --- Quote Start ---
    --- Quote End ---
    --- Quote Start ---
    --- Quote End ---
    Synchronization between clock domains and making sure your clocks/pll's are setup correctly are always concerns. .If you can get it running in a dev board before you spin your board,
    Pete
    --- Quote Start ---
    --- Quote End ---
    I'm unable to relate this statement to the HDMI specification. I wonder where you got it from? The HDMI physical layer is covered by Cyclone 3 LVDS transmitters as far as I see.
