ADhar4
7 years agoHaving communication issue b/w FPGA to Application
Hai I have developed the code for UDP packet to send the data through Ethernet using cyclon v phy marvel 88E1111-B0-NDC2I000 make ->when i try to receive the UDP packet in wireshark application i...
Deshi_Intel
7 years agoHi Arun,
If I understand your problem statement correctly, you are explaining
1) FPGA <-> wireshark (ok)
2) FPGA <-> your own application design (not ok)
Then perhaps you want to find out what's the design difference between your application vs wireshark. This should give you some clue to the issue root cause.
Deshi
