15 years agoHardware VS Software
I am doing some performance analysis for hardware and software. The program will generate a set of random 32 bits number. these numbers will be send to a user peripheral (hardware) for addition. then...
15 years agoHi! I downloaded your adder zip but could not open it, either invalid or corrupted message.
I think using SOPC builder with an avalon master slave to access memory is what you want, Then put the numbers in memory(which you probably already have). Then have the slave request 2 numbers(by address), do the adds then write the sum to memory. Of course I don't know if you add and write the sum after each add or do a summation then write that result.
