16 years agoHardware Reference Design
Hello I have been looking for a very simple programming circuit for cyclone III FPGA's for the past 6 months or so, and have not been able to find one...then the next thing I know bemicro came out wi...
16 years ago --- Quote Start --- I believe the FTDI chip on the BeMicro gets all of its startup information from the little microchip EEPROM on the board. --- Quote End --- Yes, that can be expected. It's the same with USB Blaster. It's clear, that FT2232 can be used as a JTAG adapter without additional logic (except for the configuration EEPROM). I wanted to know from someone, who owns the bemicro, if it's done there this way. The first question is about the exact FTDI chip type. I only have the bemicro manual, and I can't clearly see from the assembly drawing if there's any PLD chip that could be possibly work as additional JTAG glue logic. Perhaps someone can share a high resolution photo of the board to identify the assembled parts.
