19 years agoHardware connection to FPGA
Hi... I need small help.. I have Encoder which has one input MTINP (3 bit/3 wire) and MTOUT (3 wire/3 bit).now i want to connect to this pins to FPGA(EP1C3 module)..if suppose i will rotat...
19 years agoIf I understood You correctly, You want to create a bidirectional port. There, You must create a tri-state buffer. It may look something like this:
Port : inout std_logic_vector (2 downto 0); And then in architecture section you must define tri-state buffer: Port <= Port_out when Out_enable = '1' else (others => 'Z'); If You want to use Port as output You must turn Out_enable signal to '1'. Otherwise it will work as input. Hope I made it clear to You :)
