14 years agohardcoding the contents into memory
I have a predefined set of test data (frames which contain 256 bits), which i want to test my DUT with. I wish to know how can i hardcode the data into memory (on-chip or off chip). So that I can take each frame and pass it to my DUT and check the results. thanks for your time..:)1 Reply
If you created the memory block with the megawizard or are instantiating a megafunction in your code, then you can supply a parameter with the name of a .hex or .mif file describing the memory contents.
If you instantiate it from HDL code, you can directly give the contents using an array. Have a look at the Altera recommended HDL style document.
