14 years agoHandling large arrays in VHDL
I have a constant array of integers (2^8 words deep) declared in VHDL. Each entry is a random number in the range 0-65535. There is a nonlinear mapping between the random numbers and the index of the...
14 years ago --- Quote Start --- Perhaps you can be a little clearer on what is non-linear. --- Quote End --- The attached jpeg file hopefully makes it clearer. The x-axis represents the random numbers and the y-axis is the "bins" (1-256). In a mathematical sense, there is a many-to-one relationship: many random numbers map to the same bin. The values stored in the array are the lower and upper limits for a particular bin. In the example in my first post, any random number generated between 19 & 54 corresponds to Bin 2.
