14 years agogritch noise
actually, I made a system with my FPGA. that works fine. after that I want to check signals inside. so, I attached signal tap II on same system. once I attach signal tap II. the sign...
14 years agoBefore reading the report you need to define an sdc file that lists all your constraints. Most importantly all your clocks inputs and fast I/O. Only then you can start and reading the reports and find out how to solve the timing problems.
There is a very good user guide here (http://www.alterawiki.com/wiki/timequest_user_guide) and you should be able to find some Timequest tutorials on the Altera website.
