14 years agogritch noise
actually, I made a system with my FPGA. that works fine. after that I want to check signals inside. so, I attached signal tap II on same system. once I attach signal tap II. the sign...
14 years agothank you for quick answer.
I would like to ask you one more. I am not good at timing adjustment. (quite few knowledge of time quest timing analyzer) which way is fast to learn timing check / timing adjustment. this means that when QuartusII give me a report, I have no idea with the numbers. the red letter might be bad, bad how bad it is? and if I want to correct those, which parameter should I change? I want to learn those things. thanks anyway.
