14 years agoGPIO MHz Operation, What is OK?
I am using the DE1 board with EP2C20F484C7. I am wanting to send out data to external custom circuitry: op-amps, fiber optic drivers, etc. I want to send data at about 25MHz max if I can. ...
14 years agois this for ADAT or TOSLINK? looks like fun
ideally you would do simulations on your I/O using IBIS models and HyperLynx or compatible software. you stick in a model of the FPGA I/O, a model of the trace, and the far side I/O model. you can then tweak the drive strength, slew rate, and termination resistors to optimize the signal integrity on the other hand that may be overkill for a senior project
