12 years agoGiving external input to Triple Speed Ethernet
Hello everybody, I want to modify the tutorial "using Triple Speed Ethernet" according to my requirement. In brief what I used is: Qsys(Hardware Generation), NIOS II Eclipse(ApplicationSoftware...
12 years agoHi,
I am little bit confused about control signal of DEMUX in the design (attachment above). Because in "UDP offload example", there are 4 channels which is controlled by channel signal coming from "UDP channel mapper component" for DEMUX. But in my case (Point to point system: see attachment above), I just need to distinguish in DEMUX which signal goes to NIOSII Processor and which signal to hardware and I am confused about control signal of DEMUX. Could anybody please explain it?
