12 years agoGetting started - help and shortcuts needed
Hello, I'm looking for help, shortcuts, and links to get started. My background: Years ago, I took a 1 day intro class by an Altera distributor. I don't remember much from the class. E...
12 years ago --- Quote Start --- 1. Would it be easier to work in Windows? I've seen some postings about problems getting a USB blaster working in Linux. --- Quote End --- If you are familiar with Linux, use Linux. Getting the USB Blaster to work isn't really a "problem", it is just that it is not done automatically for you by the installer and you may need to edit a configuration file or two. --- Quote Start --- 2. Would it be better to start with the DE2 or the BeMicro? My goal is learning and playing. --- Quote End --- Unfortunately, the older BeMicro SDK has an LPDDR external memory which you need a 3rd party IP core to use. This also isn't really a "problem" except it is probably a little more complication than you need starting out. A big perk of the BeMicro is that it is laptop (couch) friendly.
