13 years agoGenerating a signal with noise
What i am doing is i am trying to do is add random numbers to a signal to find PSD later. I wrote a code for random numbers generator which is working fine shown below:
LIBRARY ieee; USE ieee.std_logic_1164.ALL; ENTITY random IS ------> Interface GENERIC (n : INTEGER := 32); -- Input bit width PORT( clk : IN STD_LOGIC; random_num : OUT STD_LOGIC_VECTOR (n-1 DOWNTO 0) ); END random; ARCHITECTURE Behavioral of random is BEGIN PROCESS(clk) VARIABLE rand_temp : STD_LOGIC_VECTOR(n-1 DOWNTO 0) := (n-1 => '1' , OTHERS => '0'); VARIABLE temp : STD_LOGIC := '0'; BEGIN IF(RISING_EDGE(clk)) THEN temp := rand_temp(n-1) XOR rand_temp(n-2); rand_temp(n-1 DOWNTO 1) := rand_temp(n-2 DOWNTO 0); rand_temp(0) := temp; END IF; random_num <= rand_temp; END PROCESS; END; After that i tried to add the random signal to a known signal to get a new signal so i can find PSD. I wrote a code for that and i am getting some errors. The code is PACKAGE n_bit_int IS-- User-defined type SUBTYPE BITS32 IS INTEGER RANGE -2**32 TO 2**32-1; -- -256 ~255 SUBTYPE BITS33 IS INTEGER RANGE -2**33 TO 2**33-1; -- -512 ~511 END PACKAGE n_bit_int; LIBRARY WORK; USE WORK.n_bit_int.ALL; LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_ARITH.ALL; USE IEEE.MATH_REAL.ALL; ENTITY cumulants IS GENERIC (n : INTEGER := 32); PORT( clk : IN STD_LOGIC; x0 : IN BITS32; x1 : IN BITS32; x2 : IN BITS32; x3 : IN BITS32; y0 : OUT BITS33; y1 : OUT BITS33; y2 : OUT BITS33; y3 : OUT BITS33 ); END ENTITY cumulants; ARCHITECTURE Behavioral of cumulants is COMPONENT random PORT( clk : IN STD_LOGIC; random_num : OUT STD_LOGIC_VECTOR (n-1 DOWNTO 0) ); END COMPONENT random; BEGIN PROCESS VARIABLE rand_temp : STD_LOGIC_VECTOR(n-1 DOWNTO 0); BEGIN u1 : PORT MAP ( clk => clk1, random => rand_temp ); y0 <= x0 + rand_temp; y1 <= x1 + rand_temp; y2 <= x2 + rand_temp; y3 <= x3 + rand_temp; END PROCESS; END; The errors are Error (10500): VHDL syntax error at cumulants.vhd(49) near text "PORT"; expecting "(", or an identifier ("port" is a reserved keyword), or a sequential statement Error (10500): VHDL syntax error at cumulants.vhd(49) near text ";"; expecting ":=", or "<=" Please help me. Where am i going wrong.22 Replies
If you need a random number generator that you can synthesize, then look at this tutorial and code:
http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial.pdf http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial_src.zip In the code you have above, it looks like you are using a linear feedback shift register (LFSR) to generate your random noise. An LFSR is used to generate a pseudo-random binary sequence (PRBS), but its only one bit of the LFSR that actually has a random characteristic (that is why PRBS has binary in the name). In the code above, you are using the full LFSR register contents, and these are not random. The tutorial shows how you can create a multi-bit output LFSR/PRBS generator (and provides VHDL code to do so). Cheers, Dave - Altera_Forum
try this:
u1 : random PORT MAP ( clk => clk1, random => rand_temp ); you forgot the random before the port map. Is this just for testbench code? VHDL already has a built in random number generator for testbenches.
