13 years agoGenerating a signal with noise
What i am doing is i am trying to do is add random numbers to a signal to find PSD later. I wrote a code for random numbers generator which is working fine shown below: LIBRARY ieee; USE ie...
13 years agoIf you need a random number generator that you can synthesize, then look at this tutorial and code:
http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial.pdf http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial_src.zip In the code you have above, it looks like you are using a linear feedback shift register (LFSR) to generate your random noise. An LFSR is used to generate a pseudo-random binary sequence (PRBS), but its only one bit of the LFSR that actually has a random characteristic (that is why PRBS has binary in the name). In the code above, you are using the full LFSR register contents, and these are not random. The tutorial shows how you can create a multi-bit output LFSR/PRBS generator (and provides VHDL code to do so). Cheers, Dave
