15 years agogenerate problem
Hi friends, I try to replicate a module by N (parameter) times. Each small instance is connected (wire) with prev and next. In original design (fixed 8 cells) I just declared 8 wires wire ...
15 years agoPerhaps zuzu22 wants to say that he is constrained to use out7 from the external design.
He can generate the architecture using out[7] but he then needs a module that translate these signal inputs in out7. It seems that he wants to "construct" the name of the signal using "i". I don't know how to solve the problem, however.
