14 years agoGenerate patterns through CPLD(MAXII)?
I'm new to FPGA/CPLD. Could any one help me? I'm wondering if I can use CPLD/FPGA to generate some patterns to output pins? This is for some simple test purpose. For example, under 50MHz clo...
14 years ago --- Quote Start --- I need to correct my statement. 1. My intention is to have simple test to microcontrollers (not specific one). For ex. Idd/power consumption, flash operation. 2. Some MCUs are not desgined with JTAG interface for test but they have similar serial interfaces (may be some specific protocols) that I have to deal with. Each one might be different. 3. As a result, I plan to use FPGA to generate patterns to access the chips. The patterns that I need to geneate would around be 2-10 pins. And there will be up to 10~30 types of patterns for each pin to enter test mode and setup control signals. --- Quote End --- For that you will need an ADC and analog power sensing circuits. There's nothing wrong with using an FPGA for this, but I would personally implement this type of logic using a microcontroller. It sounds mostly like bit banging. --- Quote Start --- As a result, I need to make up my mind: 1. Which FPGA/CPLD would be suitable for me 2. How to generate patterns, simply through shift registers and input patterns from my laptop? --- Quote End --- Any FPGA or CPLD is suitable. An FPGA has the advantage of having on-chip memory that can be used for the logic analyzer, and have more logic elements, but they need a boot device, since they are SRAM based. Before selecting an FPGA, you need to determine what your analog sensor requirements are. Cheers, Dave
