16 years agoGenerate-for loop to reset array?
Using Modelsim, I can do this in some module: ... reg [7:0] ram0 [63:0]; reg [7:0] ram1 [63:0]; reg [7:0] ram2 [63:0]; reg [7:0] ram3 [63:0]; wire strobe; wire ...
16 years ago --- Quote Start --- You should consider, that introducing a reset action prevents implementation of the register file in internal RAM. A power on reset to zero or a defined content is possible, however. --- Quote End --- That is quite the intent. This allows me to clock the register file on the (rare) writes and read it statically. Saves power, FWiW (and in the vanilla-version ASIC I'm modeling, it does matter). I actually intend to use the "strobe" signal as the clock, but simplified it here for clarity.
