10 years agoGenerate 10 phase clock for 10 ADC from Cyclone III - Is it possible?
Hi, I want to ask more you experienced, is it possible with Cyclone III to generate clock for 10 ADCs (by 1/10 phase) at 100MHz so total sample rate will be 1GSps, it act also as data buffer, o...
10 years agoYes - indeed you can. However, the GCLK network is a set of low latency paths intended to clock the internal logic of your FPGA. Depending on the part you use you'll have 10 or 20 GCLK resources available to you. If you use these up simply routing PLL clock output phases (that aren't used inside the FPGA) to I/O pins, then you will run out of these resources quickly. Depending on how full your FPGA is this could cause Quartus difficulty in fitting your design and making it meet timing.
--- Quote Start --- Only the C0 output counter can feed the dedicated external clock outputs. --- Quote End --- This is a low latency path whose delay will differ from any other PLL output clock phases routed to I/O via GCLK. So, you may end up with a set of clock signals whose relative phases aren't quite what you want. If you're careful - yes - this could all be made to work. However, if it were me, I'd use an external clock generator. Cheers, Alex
