14 years agoGate timing simulation with ModelSim Altera
Dear all, I'm using quartusII to synthesize my design. I want to run gate-timing-simulation with ModelSim-Altera. I did the following steps : 1- Synthesize design with Quartus II 2- ...
14 years agoDear all,
I would like to give you more detail about my problem : 1- EDA setting : A- Design Entry/Synthesis : None B- Simulation : ModelSim-Altera - Verilog HDL C- Timing Analysis : None D- Formal Verification : None E- Board-Level : all None 2- I create a project, and compile it successfully. 3- After finishing compiling, I start gate-level simulation : Tools -> Run Simulation Tool -> Gate Level Simulation -> ModelSim is started and compile the design. 4- ModelSim is started with the following messages : # Reading D:/altera/11.1/modelsim_ase/tcl/vsim/pref.tcl # do addersubstractor_run_msim_gate_verilog.do # if {[file exists gate_work]} {# vdel -lib gate_work -all# }# vlib gate_work# vmap work gate_work# Copying d:\altera\11.1\modelsim_ase\win32aloem/../modelsim.ini to modelsim.ini# Modifying modelsim.ini# ** Warning: Copied d:\altera\11.1\modelsim_ase\win32aloem/../modelsim.ini to modelsim.ini.# Updated modelsim.ini.# # vlog -vlog01compat -work work +incdir+. {addersubstractor.vo}# Model Technology ModelSim ALTERA vlog 10.0c Compiler 2011.09 Sep 21 2011# -- Compiling module addersubtractor# # Top level modules:# addersubtractor 5- Then I start simulation : Simulate -> Start Simulation The following errors appear # ** Error: (vsim-3033) addersubstractor.vo(3478): Instantiation of 'cycloneii_io' failed. The design unit was not found.# Region: /addersubtractor# Searched libraries:# E:\QuartusII_tutorial\simulation\modelsim\gate_work# ** Error: (vsim-3033) addersubstractor.vo(3514): Instantiation of 'cycloneii_io' failed. The design unit was not found.# Region: /addersubtractor# Searched libraries:# E:\QuartusII_tutorial\simulation\modelsim\gate_work# ** Error: (vsim-3033) addersubstractor.vo(3550): Instantiation of 'cycloneii_io' failed. The design unit was not found.# Region: /addersubtractor# Searched libraries:# E:\QuartusII_tutorial\simulation\modelsim\gate_work# ** Error: (vsim-3033) addersubstractor.vo(3586): Instantiation of 'cycloneii_io' failed. The design unit was not found.# Region: /addersubtractor# Searched libraries:# E:\QuartusII_tutorial\simulation\modelsim\gate_work# ** Error: (vsim-3033) addersubstractor.vo(3622): Instantiation of 'cycloneii_io' failed. The design unit was not found.# Region: /addersubtractor# Searched libraries:# E:\QuartusII_tutorial\simulation\modelsim\gate_work# ** Error: (vsim-3033) addersubstractor.vo(3658): Instantiation of 'cycloneii_io' failed. The design unit was not found.# Region: /addersubtractor# Searched libraries:# E:\QuartusII_tutorial\simulation\modelsim\gate_work# Error loading design I think that ModelSim dose not understand the library. Could you please give me some advices ? Thank you, Best regards, Thanh Tran.
