16 years agoGate-level Simulation
Hi , I am working on a design , it has a top level VHDL file ( a main state machine in it) and then a UART is enabled from this Main ( State machine ) . Everything works fine in RTL simulat...
16 years agoThe RTL simulation screenshots you've posted don't cover the same time frame as the gate-level simuation screenshots.
Also, I'd also suggest that you take a good look at the uut input and output signals, in order not to hide any missing connections For example, I don't a /tb_ssi/uut/clk signal in the simulations. I guess it's problably the same signal as one of the /tb_ssi/clk* signals, but I don't know which. This makes it impossible to compare your results.
