16 years agoGate-level Simulation
Hi , I am working on a design , it has a top level VHDL file ( a main state machine in it) and then a UART is enabled from this Main ( State machine ) . Everything works fine in RTL simulat...
16 years agoWhat is that doesn't start?
Modelsim? The Uart? The FSM? If Modelsim starts, do you see the input signal that switch? Do you see the outputs of the FSM that switch?
