19 years agoFunctional simulation problem
I wrote my first design in AHDL and it complied fine. When i did the functional simulation. I added various nodes in the simulation which contained both Input/Output pins and buried registers. My pro...
19 years ago --- Quote Start --- yes there are and that is not the only one register that disappears.. there are several more.. actually any register that i add, it disappears but that is not the case of I/O Pins.. :confused: --- Quote End --- Once you add and remove registers in your top project. You must compile the project and change your _.vwf again. That's why you can't find the registers. Good luck.
