19 years agoFunctional simulation problem
I wrote my first design in AHDL and it complied fine. When i did the functional simulation. I added various nodes in the simulation which contained both Input/Output pins and buried registers. My pro...
19 years agohere is the code. i have using Quartus ver 7. there a vector waveform file as well. try this:
add registers to the waveform file and run the functional simulator. then go back to the file. you will see, what i meant.
