9 years agoFunction of Pin L2 in Max10 U169 package (10M16SAU169)?
Does anyone know the function of pins L2 N12 L13 C13 A5 on the MAX 10 U169 package? (e.g. part# 10M16SAU169) Altera's pin description files leave the associated lines essentially blank. The Qua...
9 years agoOK, thanks very much for your help. After reading through the documentation I still have not found these pins mentioned anywhere but the mostly blank lines in the pinout files; maybe the designers have some kind of future migration in mind. As you suggest, Quartus does allow defining them as IO.
In a possibly misguided and maybe ultimately futile attempt to do the layout on a 2-layer board, I am running several lines across unused pins on the top layer so as to maintain ground continuity on the bottom. It is a challenge, at any rate.
