13 years ago
FTDI FT2232H Sync FIFO + FPGA
Hi guys,
I'm using Morph-IC II and i'm having problems establishing the usb-communication between my Cyclone 2 and the FTDI FT2232H.
My objective is to send a start/reset signal from PC->FPGA, then access the data from the FPGA till an end/reset signal.
My problem is now the combination of sending/receiving.
I configured the FTDI in Synchronous FIFO Mode(getting the 60MHz clk) and it works fine when i send only in 1 direction.
This task has not to be parallel,it should go like this:
PC->START->FPGA switch to read
FPGA->DATA->PC switch to write
PC->STOP->FPGA
(VHDL)
To achieve this I have a state machine for sending and one for receiving. These 2 are working fine when i only use one and comment out the other...
By the way,if I comment out only the line where i access the data it works also,but without data not very useful^^
I dont know exactly how i should switch between the write/read state machines...right now i react on RXF low,which indicates that the FTDI(PC)
has data to send,because the PC sends only start/stop/reset-commands,i prefer these.
On PC(C#) side I use the D2XX-drivers. Init the Module and use SetBitMode to go into Synchronous FIFO,then read/write with the FTDI-functions.
I've read something about configuring the data-pins as in/output with the SetBitMode-Mask,but i didn't made progress using this.
Has anyone of you done this before and can help me? Is it possible to serial read/write in this mode or only 1 direction possible?
Any hints are welcome :), if you need more informations,code,... just say
Thank you very much for help,
Andreas
    Hi Günther,
    --- Quote Start ---
    since I'm planning to use exactly this setup, do you mind sharing your source? I really don't want to re-invent the wheel.
    --- Quote End ---
    Sure.
    How familiar are you with Qsys and IP cores?
    Do you have a top-level design for your FPGA project yet, eg., a top-level entity and a pin assignments script? If you do, sent it to me, and I'll create a dummy project with a Qsys system and the bridge included. That'll allow me to ensure that I've included all the correct files.
    Cheers,
    Dave
    Hi Dave/Stylopath,
    regards,
    Günther
    Thank you,I will read through your document,hope I find help there
    any other suggestions?
    --> Working now,thank you for help!!!
    • hon1's avatar
      hon1
      Hi Dave,
      I hope to learn from your notes on interfacing the FTDI chip but the link is not working. Possible for you to post your notes again?
      Best,
      Hon
