13 years agoFTDI FT2232H Sync FIFO + FPGA
Hi guys, I'm using Morph-IC II and i'm having problems establishing the usb-communication between my Cyclone 2 and the FTDI FT2232H. My objective is to send a start/reset signal from PC->...
11 years agoHi Günther,
--- Quote Start --- since I'm planning to use exactly this setup, do you mind sharing your source? I really don't want to re-invent the wheel. --- Quote End --- Sure. How familiar are you with Qsys and IP cores? Do you have a top-level design for your FPGA project yet, eg., a top-level entity and a pin assignments script? If you do, sent it to me, and I'll create a dummy project with a Qsys system and the bridge included. That'll allow me to ensure that I've included all the correct files. Cheers, Dave
