9 years agoFT2232H in Sync FIFO Mode - TXE# stuck high
hi,
I have a Moprh-IC-II board and I'm trying to communicate via USB with a FT2232H in Sync FIFO Mode and D2XX Drivers. I manage to have the 60MHz clock input (my main fpga clock) from the ft2232h, and i can transfer data from the PC to my fpga via ft2232h with FT_Write(). FIFO Mode seems to work as expected on this side. The RXF# signal is working, going low when needed (I'm checking signals with SignalTap). But I can't send data from my fpga to the pc, the TXE# signal (active low) is stuck high and I can't find how to have it low to be able to receive data... If you have any idea on what my issue could come from ? Tank you, Alexis
