10 years agoFT2232H in Sync FIFO Mode - TXE# stuck high
hi, I have a Moprh-IC-II board and I'm trying to communicate via USB with a FT2232H in Sync FIFO Mode and D2XX Drivers. I manage to have the 60MHz clock input (my main fpga clock) from the...
10 years agoHi,
SOLVED : I'm not using the "USB Remote WakeUp" mode, and the master I had taken from the FTDI project of AN_165 was completely ignoring the pin SIWU. At first sight, it seemed quite ok and I didn't question it. BUT, when unused, the SIWU pin has to receive '1'... PS: is it possible to mark a thread as Solved in alteraforum? I'd like to THANK YOU gj_leeson for everything you've done to help me! Alexis.
