8 years agoFSM POR/Reset State on Cyclone 10 LP
This should be trivial, but I've never experienced this issue and I can't seem to solve it! I have a very simple FSM that I use to emulate a switch (given the press of a button). I debounce the butto...
8 years agoHi,
Have you checked this code work as you expected by using test bench? Have you got the correct result after simulation? For this code simulation always showing OFF state for rst_n (Reset) either High or Low. Check screenshot. Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation)
