8 years agoFSM Caught in impossible State
Hey all, So I've been developing an FPGA (Cyclone 3 Series) that basically sits between an FX3 USB 3 micro-controller and the HPI interface of a DSP. My problem lies withing my FSM, that is res...
8 years ago --- Quote Start --- For some reason after I changed the signal that the wait_read_mult_done state was dependant on, the FSM now works. I guess the mult_done_sig only being high for 1 clock cycle wasn't long enough for the state machine to capture it? --- Quote End --- This would only be the case if the mult_done_sig was not synchronised properly into the same clock domain as the state machine, Or it failed timing (and you havent checked timing)
