17 years agoFrequency divider
I am making a circuit that needs a delay block. The clock frequency is 1MHz and I want the delay block to send a HIGH signal after about 10ms so basically I shall have to divide the frequency by 1000...
17 years agoSounds like your counters are asynchronous. If you use synchronous ones you'll probably find life a whole lot easier.
