9 years agofreeze root of all design after every change in it
Hi, I am implementing a communication system on the 114 k logic cyclone IV FPGA using Quartus 11.1 and My design use 80% of the chip. adding or removing every block to design can result to destroy...
9 years agoUnfortunately, using a relatively large device that is very full is going to be time consuming...
--- Quote Start --- use tsu and thold to over come these bad complition? --- Quote End --- I'm not sure what you mean by this. These are not parameters you can adjust. A poor design may not meet the tsu required for it to operate at a particular clock frequency. So, it will fail timing. If this is the case you need to look at your code. Cheers, Alex
