Yarko
2 years agoFrame Buffer Avalon Stream problem
Hello, I'm using IP cores from Video and Vision Processing Suite Intel® FPGA IP to process my video stream. I came across a problem and simplified the video pipeline to the following: Custom TPG -...
- 2 years ago
The problem turned out to be a missing constraints.
Yarko
2 years agoThere is one more example:
- The value 83 is transmitted correctly and is hold when the valid signal drops.
- But the value 139 is not recognized because the valid signal is 0.
