SJadh1
7 years agofPLL loose lock debug help request
I am using Arria 10 GX FPGA Development board.
I am debugging a fPLL lock issue.
In current design fPLL instance gets reference clock from the recovered clock of transceiver.
CDR block of transceiver is configured for manual mode.
Currently I am manually setting CDR block to LTR mode. I do see expected and stable recovered clock.
But unable to get fPLL locked to this recovered clock.
Any help as to debug will be really helpful.
Thanks & Regards,
Sachin Jadhav
1 Reply
- SreekumarR_G_Intel
Hello Sachin, Can you check the pll_cal_busy status ? if it is High can you disable the cal and check the same? Also can you send me the fPLL setting with input and output Frequency ? Thank you, Regards, Sree
