FPGAs with Feedback issues
- 4 years ago
Here is how I would rewrite your paragraph (rather significantly):
FPGAs are programmable devices that allow you to create custom logic designs in hardware without the need to build an ASIC or use multiple chips on a board. They can be reprogrammed with the same or a different design "in situ" at any time. You can simulate an FPGA design in a simulation tool, but that design can then be implemented with full functionality in the FPGA. An FPGA design is created, compiled, and programmed using the manufacturer's software. This is especially important to engineers creating novel circuits because they don't require any other hardware on their board to implement the circuit other than just the FPGA. FPGA designs are typically created in a hardware description language (HDL) to describe the behavior of the circuit and then compiled by the design software. The design software has many debugging tools to help with everything from creating the initial design all the way through testing the design while it's running in the FPGA.
Side note: while FPGAs can be used for ASIC prototyping (which I think is what you are thinking about here), this is not a huge part of the development base for these devices.
Thanks sstrell !!!
FPGAs are made up of logic gates that are routed together and easily rerouted using HDL and the software provided. Manufacturers of FPGAs create development boards that include additional hardware devices such as real time clocks, CPUs, and I/O that can be routed to the configured FPGAs. Have I written anything false? or perhaps it can be rewritten better?
So HDLs are not the only way to create logic designs of FPGAs? What other ways are there?
ASICs are expensive right, that's a reason to use FPGAs as an end product?
Thanks again!
I welcome others to answer as well. Thank you!
Well, most dev kits don't have a separate CPU. You can implement that in the FPGA, either a soft processor made up of FPGA logic resources (Intel's soft processors are called Nios II and now the new Nios V) or a hard processor on the same FPGA die (Intel uses ARM Cortex processors in their SoC devices).
You can create a design in many ways. HDL is the main way, but you can create a schematic, build a system design graphically (Platform Designer in Quartus), or through software development (oneAPI, HLS, OpenCL).
Yes, ASICs have a large initial upfront cost to create the fab for the chip, and if there is the slightest error in the design, you have to redo it. With an FPGA, if an error in the design is found, just fix it in the design tool and reprogram the device, which can even be done in the field.
