11 years agoFPGA2SDRAM subsystem
Hello all, I'd like to use FPGA2SDRAM subsystem. Thus i added 2 ports in HPS properties in Qsys (mm read & mm write). I generated preloader and u-boot and put them in mmcblockp3 of my sdcard....
11 years agoHi,
the ARM could write the whole RAM connected to the HPS-Side. How to write and read, depends on many factors, such as if you are using Linux, if you need to cache the Memory-Region, etc. Please be so kind to tell a bit more of your needs.
