lutzek
4 years agoFPGA to microcontroller interface short circuit protection
In my design I have microcontroller and MAX10. I have SPI and USART between these two. What is a good practice to protect these two circuits in case of mistake in pin configuration during wr...
ak6dn
4 years agoIf you have control of what parts are attached on each I/O line adding any kind of 'protection' is really not necessary.
That being said, I have several commercial FPGA development boards that have FPGA I/O pins that attach to user connectors.
Some of these boards have just a series resistor in the range of 22 to 47 ohms.
Others also have diode clamps to VCC and GND on each I/O line.
If you can't control what is connected this extra circuitry helps a bit (but it is not foolproof).
lutzek
4 years agoThank you for your answer. In general what I mean is like connection between FPGA and Microcontroller. I suppose, that if both are push-pull, both configured (by accident) as outputs, first is high, second is low - that might be not fun for both of these ICs.
