12 years ago
FPGA-to-HPS SDRAM Interface blocks whole HPS
I have configured in QSYS f2h_sdram0 as Avalon-MM Bidirectional with a width of 64 bits.
Whatever I connect to this interface, blocks the HPS when I run "run bridge_enable_handoff" in the uboot console.
( Tried the SGDMA which freezes instantly, the NIOS II core which freezes upon a RAM access... )
Preloader and uboot are of course regenerated each time I change the design.
What can be the reason of this behaviour? Misconfiguration of pin assignments to the RAM in Quartus?
But Linux seems to work on the HPS.
Hannes
Edit: With security enabled at least no freeze with the SGDMA.
Edit2: If I forgot to mention something important, please tell me.
When frozen, everything on the f2h_sdram0 is set to 0 (data address, data_burstcount, data_byteenable, data_writedata, data_readdata)
Is this important? Is there anything I can test using Signaltap?
    Hey! Now works fine for me too :).
    But i really don't understand why we need to do that.
    Anyone knows???
    Is that the "device tree" can help ?
    Nico
    I wonder if it would also work if the FPGA was configured from Linux. You would need to wait for configuration to finish, enable the FPGA-to-HPS SDRAM bridge, and only then make an access from the FPGA.
