12 years agoFPGA-to-HPS SDRAM Interface blocks whole HPS
Hello, I have configured in QSYS f2h_sdram0 as Avalon-MM Bidirectional with a width of 64 bits. Whatever I connect to this interface, blocks the HPS when I run "run bridge_enable_handoff" in ...
12 years agoI have a similar problem. The ARM freezes not after enabling the bridges but at the first read access from the FPGA side to the SDRAM. After a cold reset all works fine and no freezes are seen. That happens only after a power-up.
Philipp
