16 years agoFPGA specific timing requirement
I need to output a pulse signal from the FPGA that is very time sensitive. I would like to have control of the period by a resolution of 2 ns. This would require a 500 MHz output clock. Briefly looki...
16 years agoYes, using both edges of the clock.
By better, I meant a bit better than 2 ns but way above 1 ns. In the end, your resolutions is going to be limited not just by FPGAs internals but also by the signal's rise/fall time, noise, etc. If the on time or the off time is very short (say, 2 ns), you might run into minimum pulse width issues, if you're using, say, 3.3 LVCMOS signals. Board design will be important. I'm not seeing how to combine 4 clocks with different phases to produce a better resolution. It may be possible, but I don't see how.
