14 years agoFPGA replace CPLD
I have a hdl program with several array such as [31:0] , [12:0] and [16:0] , only FPGA can holds such a large memory , one problem I faced is no NIOS II CPU is used and wish to remember the program a...
14 years agoThe serial flash loader can only be used on Cyclones III or later, so with a Cyclone II you will have to put a connector to configure the flash memory, in addition to the JTAG connector. Have a look at figure 13-7 in this document (http://www.altera.com/literature/hb/cyc2/cyc2_cii51013.pdf). (and you should read all this document, it has interesting information about configuration).
