16 years agoFpga_"PHY" to RJ45 with transformer
Hello guys, I want to connect the Pluto2 fpga board which is trasmitting only to a Pulse RJ45 J006. I will connect the pin_4 to a 100nF Cap on th GND. And i am not sure about what to do ne...
16 years agoI don't claim to solve your problem from a distance, particularly as you didn't give much details on the pulse scheme and I/O settings at the FPGA side. But I simply assume, that you are using double push-pull drivers with a scheme as sketched above. Then, as said, "the center tap must be allowed to float". It's the same with integrated PHY controller chips like Davicom DM9008, they are known to fail in operation, if you connect a capacitor at the Tx center tap. True differential current source drivers in contrast have no problem with bypassing the center tap, or even require it.
