16 years agoFPGA packages for PCB design
Hi all, does anyone know if there is some sort of automatic tool for creation of EAGLE CadSoft - compatible libraries with Altera FPGAs? I've checked user contribution page on the EAGLE websit...
16 years agoI have done something similar as well. Although, instead of starting from the pinout spreadsheet from Altera, I imported the fitter pin-out file into Excel. This way, all your application signal names can be used. I used an Excel macro to split up the part into separate gates based on prefixes in the signal names. Using Excel formulas, I formatted the data so that PADs could import the data as a CSV file.
