16 years agoFPGA packages for PCB design
Hi all, does anyone know if there is some sort of automatic tool for creation of EAGLE CadSoft - compatible libraries with Altera FPGAs? I've checked user contribution page on the EAGLE websit...
16 years ago@thepancake:
as promised, I'm attaching the ULP script file I used with EAGLE. It should be quite easy to use... just rename the file attached to this post to .ulp and run it from a library edit window of EAGLE. @donq: your script seems much more advanced :) did you use EAGLE? are you going to make your script available to the public?
