12 years agofpga is getting heated unusually
My cyclone 3 starter kit is getting unusually getting heated up. Even before I burn the code into it, its getting heated in a few seconds as soon I switch on the power. Can someone tell me wha...
12 years ago --- Quote Start --- Which of the following states reflects what's in the FPGA's boot FLASH? a) Factory image. b) A user image - something you've already programmed in. c) It's empty - as a result of you consciously erasing it. Based on the above if it's: a) You probably have some damage to the board b) It could well be your FPGA design that is resulting in contention and too much current being drawn c) Very similar to a) Is it this board: cyclone iii fpga starter kit (http://www.altera.com/products/devkits/altera/kit-cyc3-starter.html) ? If not let me know which one you are referring to. Also, identify exactly which jumpers are fitted. Regards, Alex --- Quote End --- Yes the board is cyclone 3 starter kit FPGA. We checked the adapter , it is perfectly fine. I can't find any shorted pins also .Can anybody suggest what the reason could be? thanks in advance!
