KNGanendraMurthy
4 years agoFPGA Enumeration Failure
Hi all,
I am trying to program Intel Arria 10 GX Programmable Acceleration Card through RISC-V CPU(SoC) based Hifive Sifive Unmatched Board via PCI express.I am booting up RISC-V CPU using Ubuntu 2...
KNGanendraMurthy
4 years agoHi,
I am loading intel-fpga-pci instead of dfl-pci using 'mv' command.The name of the module is dfl-pci but actual module getting loaded is intel-fpga-pci and I am unable to see the kernel driver.Are kernel modules and drivers same??.Kindly reply
Thanks&Regards
KN Ganendra Murthy
KNGanendraMurthy
4 years agoHi,
I am attaching the output from the server system which has PAC cards attached and drivers installed.Kindly check
Thanks&Regards
KN Ganendra Murthy
