FPGA Enumeration Failure
Are you able to manually communicate with the FPGA device manually? It looks like the the PCIe communication issue where it is enumarated but not able to interface with it.
- KNGanendraMurthy4 years ago
I am trying to load intel-fpga-pci driver using 'sudo insmod intel-fpga-pci.ko' on RISC-V CPU(SoC)based Hifive Sifive Unmatched Board.I am accessing the board using Ubuntu 21.10 LTS OS.I am attaching the error being generated while loading the driver.Kindly provide solution to the problem.
Thanks&Regards
KN Ganendra Murthy
Intel Arria 10 PAC card is working properly,the drivers got installed and able to run applications on them in x86 based server systems,But facing issues while trying to do the same with RISC-V CPU
Is it possible to program Intel PAC card through RISC-V CPU using JTAG.RISC-V CPU(SoC) based Hifive Sifive Unmatched Board has a support for JTAG.What are the steps that are to be implemeted to program Intel PAC card through JTAG.Kindly mention.
Thanks&Regards
KN Ganendra Murthy
