13 years agoFPGA configuration time and PCIe secification
Has anyone used the PCIe interface of a Cyclone device while configuring it using the AS (active serial) scheme? I'm using a Cyclone IV device (EP4CGX30F484) and planning to use its PCIe interf...
12 years ago --- Quote Start --- Do You share or sell it? --- Quote End --- I'll share it. I need to look at the code and see whether I'd finished it, I got distracted and was working on something else. In your application, you want a MAX II plus QSPI Flash to configure a EP4CGX22, correct? --- Quote Start --- Your custom controller is useless for my EP4CGX22. I need PS. --- Quote End --- The only difference between PS and FPP is a shift-register. The controller handles both cases. Cheers, Dave
